Company Logo (800) 853-2651 Shop Now
? for Dr Allis or diesel engine guru
FARMER AK
10-01-2018 13:05:59
I am seriously thinking about installing a pre-filter system consisting of an electric fuel pump and filter/water separator on my AC7000 maroon belly (Ser#45**) tractor in the fuel line from the tank that goes to the box filter. I need a better way of controlling water contamination than with the box filter as this tractor sits a lot and is subjected to condensation.
System would be as follows:
1- Electric fuel pump - 34-gph, 7-10 psi (in front of --)
2- Racor filter/separator - 15-gph/5-lph, (output connected to the existing box filter)
3- All plumbing associated with the above would be 1/4" (existing line from the tank to pump would not be changed)
My questions are; 1- is this reasonable? 2- will it work okay? 3- any interference with the engine injection system? 4- any other problem(s)?
I am open to suggestions or comments.
Thank you, Farmer AK
FARMER AK
10-05-2018 09:18:20
 Re: ? for Dr Allis or diesel engine guru in reply to FARMER AK, 10-01-2018 13:05:59
Thanks to all for the info and responses given. All cause careful thought and consideration. Thanks again to all! Farmer AK
Hd6gtom
10-04-2018 14:24:28
What are you using to fIll this tractor? If it is from a portable fuel tank, do you have a hydrosorb filter in it. Those tanks are notorious for moisture. If you have a portable tank, do you have a Pre Vent cap on it or the old flip over capt hat allows moisture laden air to easily enter?. Are you using premium #2 fuel or truck stop/convince store fuel. I spent 14 years owing a fuel business and found these to be the major problems with diesel fuel.
Brian Jasper co. Ia
10-03-2018 09:50:24
Another vote for keeping the tank full unless you're having trouble with fuel theft. If there's no moist air in the tank, there will not be much, if any condensation in the tank.
Dieseltech
10-01-2018 13:18:19
While what you are planning will work OK, none of it is needed. Best way to keep condensation water out is to simply keep the tank full. Tanks that are full don't "sweat" like near empty tanks will.
FARMER AK
10-01-2018 14:21:16
 Re: ? for Dr Allis or diesel engine guru in reply to Dieseltech, 10-01-2018 13:18:19
Thanks for the response! :>)
FastFarmall
10-01-2018 19:48:51
 Re: ? for Dr Allis or diesel engine guru in reply to FARMER AK, 10-01-2018 14:21:16
I agree with Diesel Tech, becuase he's got a lot of practical experience, but, i really do believe in Howes Anti Gel Additive,i had one tractor siting inside [with a Rosa-Master pump], with Howes in the tank, for 10 years, put new battery in it, started up ! But i never used B-10 fuel or burner fuel,bought the kind with red additive in it, and i am soybean farmer too, but never used it!
FARMER AK
10-06-2018 09:25:16
 Re: ? for Dr Allis or diesel engine guru in reply to FastFarmall, 10-01-2018 19:48:51
Thanks for responding. We only use regular diesel fuel purchased from the major fuel stations/suppliers and always road/truck use type. We will look into the "Howe" product you mentioned. Thanks again! Farmer AK
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: WANTED Rumely Oil Pull Models W X or M [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
