WF Head Number
resden
Am working on a friends WF with a missing head. What is the correct casting number for the head on a WF? Friend has a whole collection of heads laying around loose but I need to know what to look for!
Any WC/WF uses the short height cylinder head. 3 or 3 1/2 inches tall. Must use the taller rocker arm shaft with the short head.
What the good Dr said, but I'll add... The first few years of WC's did not have the 3 smaller head studs along the right side of the block. I would guess the heads for those didn't either. As long as it's a short head with the same number of stud holes, you are good. You can run the head with the small stud holes on a block without, but obviously not the other way around.
AaronSEIA
