Company Logo Shop Now
Starter solenoid for an early gas D17
luke470
09-17-2018 16:11:39
Could anyone give me a part number for a replacement starter solenoid for an early D17 Gas. Serial number for the tractor is 16815.
Tractor won't turn over. Was turning over then all of a sudden nothing. Good battery. Juice to the coil. Ignition switch works so it's got to be the starter, solenoid or wiring in between. im thinking anyway.
Thanks
old
09-17-2018 17:24:58
 Re: Starter solenoid for an early gas D17 in reply to luke470, 09-17-2018 16:11:39
My D-17 series ne has a common ford type 4 wire solenoid on it. One way to test the solenoid is this. #1 make sure it is out of gear and even better block the rear tires.
#2 use a jumper wire from the small terminal to the battery cable side of the solenoid. If it spins over that way you have a bad wire or bad switch. If that does not work then #3 use a heavy jumper and go across the 2 big posts. Doing that should spin it over and if it doesn't then you have poor connections some place or a bad battery or bad cables or bad starter
Jim.ME
09-17-2018 17:18:49
Looks like 70261441 in the AGCO parts book for the D17. A Standard Motor Products SS-547A may work. The store for this site likely has one as well.
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
Latest Ad: McCormick Deering 22-36 Tractor has been restored by previous owner. Runs great looks great. Tractor has automotive paint that is really sharp. Tractor shows really well. Would make a nice addition to a IH collection. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
