ib allis chalmer
Hi all, I have purchased an IB in pieces from a salvage yard. When I saw it and realized what it was I had to save it, if nothing
else just for parts. After a year or so I decided to start rebuilding this tractor, in sorting through the parts i found that most
parts unique to the IB are there. My question is the clutch shaft that runs from the clutch shaft to the transmission is missing.
Is this shaft different from a regular B? Thanks
I would think it would be the same as the B or the C. I have 2 parts Cs on hand so I may have one
It would be shorter! The coupler can be removed from the standard drive shaft and welded onto the shaft after being cut off to the proper length.
Get on www.AGCOpartsbooks.com Log in as a guest and search for "IB". You can view the parts manual and compare what will interchange.
AaronSEIA
