170 Brakes AC
slifnom
Hi GENTS, I have an Allis 170 with bad brakes. I am totally new to AC, and would not know where to start. I have all the manuals. But I do not have the jacks and cribbing for such a job. I have a local mechanic that could handle this job. What would you
estimate for a job as such?
The price of the brake wear items is easy. Four brake bands......two disc lining kits......four band springs........four drum springs........two axle seals.........two O-rings for the differential carriers. Call an AGCO dealer for prices. Flat rate labor of 8 hrs to replace all of these, as the axle/final drives must be removed/replaced. Hydraulic lever console does NOT have to be removed to do this. If the brakes are steel-on-steel there will be more parts to buy. Are you sure the brakes just don't need to be ADJUSTED ?? Tighten each brake rod a turn at a time until the brake pedals are at the 2 to 3 inch height when applied. Don't twist off the brake rods !!! Brake rods need to be in the LOWER hole with the brake pedal return spring in the UPPER hole.
(quoted from post at 05:53:21 08/31/18) Yes, I am dragging my feet! Any simple things to start with? Thanks
..... Don't know how much simpler it gets.... Adjust the brake rods shorter (if needed) and make sure the brake rods are in the lower holes on the pedals.
