Re: AC C pistons are stuck
Dick L
07-30-2000 20:23:19
If you have the radiator off you can put a wrecking bar across the crank pully and get more torque than you can pulling it. If they are rusted bad I will pull the engine out, turn the engine over and remove the crank. Then I use an oak 2"X 2" block of wood, place it in the bottom of the piston and drive them out one at a time. If the sleeve and all comes out I soak them in diesel fuel a day or so and use a hyd press.
