Changing to negative ground..
I have a 1951 Allis Chalmers WD, I just purchased a 6 volt negative ground alternator, I want to convert the tractor to negative ground... It has a magneto ignition... I know point systems you need to swap the coil leads... does anything need to be changed on a magneto when converting to negative ground... Thanks
(quoted from post at 18:23:07 07/31/18) No. Will you be swapping the wires around on the ammeter, or using a voltmeter?
I guess I can swap the amp meter wires around... That's no big deal..
