Company Logo Shop Now
Governor on 175
bv
07-27-2018 10:00:27
How can you tell you have a problem with the governor on my 175, is it in the carb linkage or is the problem with the weights on the governor, I was disking with mine and at the turn row raising the disk the engine wants the rev up? what am I looking at here?
Traditional Farmer
07-27-2018 17:46:05
 Re: Governor on 175 in reply to bv, 07-27-2018 10:00:27
You need to check out the governor as you definitely do not want it to fly apart,hopefully Dr Allis will weigh in I'm sure he'll have a very good idea of what is happening.
bv
07-28-2018 05:47:44
 Re: Governor on 175 in reply to Traditional Farmer, 07-27-2018 17:46:05
I did bend the rod to the carb to shorten it and it's working better now but I don't understand why all the sudden the rod was too long to begin with?
Traditional Farmer
07-28-2018 08:37:35
 Re: Governor on 175 in reply to bv, 07-28-2018 05:47:44
If it was my tractor I'd be looking into the governor before I ran it anymore loose parts can cause a lot of damage.
old
07-27-2018 10:29:03
Well first off they will tend to rev. up when the load is taken off them. Or you could have a slow governor or governor to carb linkage could be binding up some place all of will cause that
bv
07-27-2018 12:37:08
 Re: Governor on 175 in reply to old, 07-27-2018 10:29:03
it's revving up more than normal, if it was a weight it would be making noise?
old
07-27-2018 14:59:19
 Re: Governor on 175 in reply to bv, 07-27-2018 12:37:08
Weight make noise not likely but a weak spring in the gov can cause that
teddy52food
07-28-2018 06:00:12
 Re: Governor on 175 in reply to old, 07-27-2018 14:59:19
Rich; you have it backwards. A weak spring won't let it rev up like it should. I would say he lost a weight.
old
07-28-2018 08:39:05
 Re: Governor on 175 in reply to teddy52food, 07-28-2018 06:00:12
I've seen a weak spring get twisted up and cause funny problems before and it gets hung on the weights etc.
bv
07-29-2018 18:44:00
 Re: Governor on 175 in reply to old, 07-28-2018 08:39:05
I pulled my unit out to check the governor weights and they are good, bent the linkage rod to the carb and it's working right now, gonna put a carb kit in and she'll be ready to go, thanks for all your help guys
Today's Featured Article - ... [Read Article]
Latest Ad: Need a grill guard for a 8n ford [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
