Company Logo Shop Now
D 17 series 1 rear wheel bearings
Paul V B
07-15-2018 16:17:58
Anyone have the Timkin bearing numbers for the final drive bearings? The part numbers on Yesterdays Tractor site does not match Agco part number. Agco parts book doesn't really get specific for series 1 2 or 3. Both mine definately need to be replaced. I did Google the Timkin cup part number from YT and a matching bearing number comes up on one site. Is there only one Timkin bearing going to fit a particular cup?
Paul V B
07-29-2018 17:17:44
 Re: D 17 series 1 rear wheel bearings in reply to Paul V B, 07-15-2018 16:17:58
I couldn't just pull the hub out . Read the outer bearing was prob slightly pressed onto the axle so I rigged up this bottle jack to press the axle out. Didn't take much effort. There is only a tiny lip to try and hit the old race out so I'll probably use a grinder and grind the old outer race off. I punched the inner race out with no problem.
Paul V B
07-29-2018 17:23:02
 Re: D 17 series 1 rear wheel bearings in reply to Paul V B, 07-29-2018 17:17:44
third party image
Paul V B
07-16-2018 19:39:19
For the outer bearing Agco shows 70229110 and Y T has 70057006 so there are two different Timken numbers. Not sure which is the correct one. Neither site is specific about serial numbers.
gatz271
07-16-2018 21:26:06
 Re: D 17 series 1 rear wheel bearings in reply to Paul V B, 07-16-2018 19:39:19
they may be the same, IDK.
On the YT page they talk about finding the correct part for the D17. see link
I'd ask them whether that is the same; and if not could they provide the correct p/n
Might want to take a pic to send if need be.
Traditional Farmer
07-16-2018 04:12:36
Should pretty easy to find look them up on ebay usually someone there will have all the numbers you need.
Mike(NEOhio)
07-15-2018 18:53:01
Run the Timken numbers in the search box on locateballbearings.com.
gatz271
07-15-2018 16:32:18
what is the p/n you googled?
here's Timken's interchange catalog;
Today's Featured Article - ... [Read Article]
Latest Ad: Need a grill guard for a 8n ford [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
