7020 allis value
krob
Found a 7020 allis. 20 speed power director transmission. 6000 hours. What potential issues should I be looking for and what price range are these tractors running?
Thx
Krob
6,000 hrs could be the end of the road for the engine if it hasn't been cared for. Before starting the engine, loosen the oil pan drain plug to the last thread and carefully let out a few drops of engine oil. THERE BETTER NOT BE ANY GREEN ANTIFREEZE !! Also check the engine oil fill rubber cap for shaving cream foam on the underside of it and make sure the radiator coolant is within 3 inches of clear full. The driveline is pretty tough as long as it hasn't been run low on oil and had filters changed. The air cond better work, or it will cost $$$$$ to fix. New rear tires are $1500 if the old ones are shot. The tractor is now 40 years old. Lots of things could have happened to it in that time.
