Company Logo (800) 853-2651 Shop Now
BRAKE PROBLEM
Leonard Dacus
03-27-2018 15:17:57
need information with brake D-17 series 4
something happened petal goes all the way down does not apply any braking on right side, has been ok for years, just happened all at once. took a quick look block that rod screws into for adjusting is loose indicating something with lower brake has something broken in lower rod area. looking for easy way to get to it to take a look without pulling axel housing.
series 4 factory 3 point hitch dual remotes, all the hyd. valves connect together mounded to axel and fender making this look like a major project. asking for any suggestions of best way to approach this project.
jim_uny
03-27-2018 18:50:38
 Re: BRAKE PROBLEM in reply to Leonard Dacus, 03-27-2018 15:17:57
steiner tractor parts has a video w/ ac d17 brake repair in WRENCHING WITH RACHEL. maybe this will help & also give a source for part
Bob Bancroft
03-27-2018 16:04:36
There is no way I know of short of pulling the axle. It is an intimidating job on the right side. I've seen all the hydraulic lines unhooked and the valve taken with the axle. I prefer to take out the four bolts holding the valve block to the support, and removing the pins on the control rods, and leaving the valve assembly intact with all the oil lines. As I recall, some of the position control/traction booster linkage has to be removed also.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
