ALLIS C CA CULTIVATOR QUESTION
JOCCO
Why will the cultivator not fit between the two? I am assuming the transmission? Can they be easily modified to work? thanks
Completely different setups. The C one mounts to a bar behind the rad and boots to the bellhousing. I think the CA one bolts to the front of the tractor. C uses a lift rod setup from a frame behind the seat and the CA uses hyd if memory serves. I suppose anything can be done but it would take a lot of work to get there.
AaronSEIA
