Company Logo Shop Now
Replacing a water pump on an Allis WD?
Dave Westlund
01-18-2018 12:11:33
Is it possible to replace a water pump on an Allis WD without removing the grill and radiator?
Secondly my water pump has a slight leak around the fan shaft/pulley. Is there a fix for this or should I bite the bullet and get a new water pump?
Your help is is much appreciated.
Dave
Dave Westlund
01-20-2018 08:25:43
 Re: Replacing a water pump on an Allis WD? in reply to Dave Westlund, 01-18-2018 12:11:33
DR A, KK and J in MI,
Thanks for the replies. What I did was started to take off the fan and decided to just remove the radiator and grill and will put in a new water pump and fan belt.
Dave
john(MI)
01-19-2018 09:49:15
You may want to replace the belt at the same time. I don't remember for sure, but I think you need to remove a hose to do it, so you might as well do it now!
Kenny kabat
01-18-2018 18:30:23
Take out 6 hood bolts and 2 underneath. You already have to drain the system. Ten more minutes and you have full access. Makes life easier.
DrAllis
01-18-2018 14:36:46
I've done it before without removing the radiator. The worst part is wrestling the four bolts that hold the fan. Also be gentle with the lower radiator hose or you might damage the radiator lower neck if you get too mean with it. Get a reman pump and do it once instead of twice.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Farmall A. A complete restoration of a 1939 Farmall A. Parade ready. Whole motor has been went through. New tires. Everything factory except the stack. Crank start only. OBO [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
