Re: Help (Again)!!
Butch(OH)
07-13-2000 04:33:36
James, The metal strip on the mag should not be touching the case unless you push it.The original switches were grounded internally and will have one terminal which is wired to the mag. If it has been replaced with a two terminal switch as some have you must ground one of the terminals and the other goes to the mag. The operation of the two terminal switch is reversed,"ON" will ground the mag. Remove the grounding wire from your mag and check for spark, If you still have no spark a trip to a mag shop is probably in order. Before you remove the mag, crank the motor until it impulses, remove the cover and note the position of the rotor so it can be reinstalled in the same position. If you have boys around like I do, hide the crank so the motor doesn't get turned while the mag is removed.
