Company Logo Shop Now
Allis B Amperes Guage
allisbchal
10-08-2017 18:19:54
Just a put a new Amperes gauge on my 1951 Allis B. Just wondering what it should be reading when the tractor is at idle. Still a 6 volt system - positive ground.
Thanks!
steve(ill)
10-08-2017 20:19:36
 Re: Allis B Amperes Guage in reply to allisbchal, 10-08-2017 18:19:54
at IDLE it should read slightly positive, maybe 1-2 amps.. If you turn on the light switch, it should jump, then go back to a couple amps.. If the battery is low, you may charge at 8-9 amps for 30 minutes, then drop back down to 1-2 amps... At idle, you may actually go slightly negative.
allisbchal
10-08-2017 20:11:17
Uh oh...I may have it backwards then. It's reading almost full "discharge." Reading about 15-16 discharge.I would think it would read charging while running?
Janicholson
10-08-2017 20:48:25
 Re: Allis B Amperes Guage in reply to allisbchal, 10-08-2017 20:11:17
If the battery is partially charged, it will put out 14 or so amps, at part throttle, not idle. Most generators will not put out much at idle. Make sure the battery is being charged by measuring the voltage across the battery it should be about 6.3 when turned off. It should measure 6.8 to 7.2 when running a 1/2 throttle or more. Jim
wbecker
10-08-2017 19:50:48
Quoting Removed, click Modern View to seeAtidle speed, the cut out relay will not have closed yet so there will be no output. It will read about 0, if you have a distributor rather than a mag, it may show a very very slight, or unreadable -, if you turn on lights it will show considerable -, maybe -10 or so.
Today's Featured Article - Bad Vibes - by Curtis Von Fange. One of the strangest ways to communicate with our tractor is to ask it how it feels. "Ask it how it feels," you say? Yup, ask it how it feels. Now, as with the other articles in this series one has to be able to hear what 'ole blue' is trying to say in response. The nice thing about our old iron friends is that they are usually quite consistent in their response, rather unlike some people I know who might change what they say due to the weather or other mitigating circumstances. But since t ... [Read Article]
Latest Ad: John Deere 855 parts manual. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
