Company Logo Shop Now
Allis B engine oil Pump
DLM
09-28-2017 15:48:26
Where can i get a thinner pump cover gasket the one that came in the gasket set is to thick it is .007 that gives me .0055 end play it should be no more than .002. I would like to find a gasket that is .003 thick because the housing is .001 below the rotor . the only other choice is to machine the housing down .0035 thanks Don
Dick L
09-29-2017 04:37:40
 Re: Allis B engine oil Pump in reply to DLM, 09-28-2017 15:48:26
If you need a .002 gasket you have more problems than the need for a thinner gasket. The rotor has wore down or the cover needs resurfaced. If the rotor has wore down they you most likely would have wear on the housing where the stem goes thru. In an oil pump .005 wear is a bunch.
If it is in the cover it can be smoother flat with a good flat file and time.
steve(ill)
09-28-2017 19:37:27
cut your own from a piece of construction paper / print paper / news paper as needed.
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
Latest Ad: 3 point drag arm for 420 HD crawler right side [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
