Company Logo Shop Now
Help with restoring a B near Spokane, Washington
Duane Becker
09-15-2017 09:13:27
Hello, I am new to posting on this forum, but need some help and guidance on restoring. I live north of Spokane, and it would be very helpful to have a knowledgeable Allis person look at my 1948 B and parts.
Mainly concentrating on the engine for now, I have the engine on the tractor and a separate engine off that is in pieces-hoping to use what I have, or combine parts for rebuild- buying what I need.
I dont know too much about engine rebuilds and plan to take to rebuild shop, but not sure if the current rebuild shops understand much about the old AC's. Any help would be appreciated.
YTSupport
09-20-2017 10:16:30
 Re: Help with restoring a B near Spokane, Washington in reply to Duane Becker, 09-15-2017 09:13:27
There is a lot of expertise here on the B, C, CA family. I'm sure we can help out with any problems you run into, just post your questions as they come up. I don't think any of us that love ACs will get tired of a new question coming up every day. That is what the forum is for.
If you want to document your experience, go ahead and use the Project Journals (in the left menu at the home page) and create a project to describe what you are doing each day. That helps me stay focused, and tell others how I end up solving a problem during the restoration.
Great tractor to start with. The first one I restored after my main working tractor was a C, very similar. I've also done a couple of Bs and even still have one of them with a nice fabricated 3-point. I think the B is especially good to work on because the parts are light and accessible, no bridge crane required.
Ralphwd45
09-20-2017 01:57:01
Hey guy! there is a member , that frequents this site, called Dick L, and he has untold pictures on his own site, of B type restorations, including engine work. By looking at Dicks pictures, almost any wrench bender, can fix a B,C, or CA. Shout out to Dick L . and use his site like You tube.
Ralphwd45
09-20-2017 02:18:34
 Re: Help with restoring a B near Spokane, Washington in reply to Ralphwd45, 09-20-2017 01:57:01
Duane! I just remembered a goof up, that I pulled 18 or 19 years ago. When you remove the rod caps, so you can push a piston up out of it's bore, be sure to carefully save the rod cap shims, and count how many is in it's respective stack. Also we have a YT member living in eastern Spokane, a little north of I90, his YT handle is Dell Wa. Might get some help from Dell.
Duane Becker
09-16-2017 08:21:48
Thanks bjb, I will take you up on that, and might be a few days or so, but I should be able to post some pics...
bjb in Tx from Ne
09-15-2017 12:17:44
If you can post or email some pictures, I should be able to help.
Latest Ad: Looking for a gearbox casing that mounts to a Clinton Machine Company motor Model B764COC Serial# 2070576 part# 3801-C. It powered a Bolen 2 wheel walk behind tractor late 1940s model. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
