Company Logo Shop Now
Allis Chalmers C Surging
Bookman
08-24-2017 14:10:08
The 1942 Allis Chalmers C I overhauled has a problem with surging. It does it soon after being started, and then it seems to settle down. Any ideas as to the problem or how to trouble shoot it?
Dick L
08-25-2017 12:01:50
 Re: Allis Chalmers C Surging in reply to Bookman, 08-24-2017 14:10:08
I have several of the B's and C's. All of my surge springs are hanging on a nail in the shed. Don't get me wrong they are there for a reason but the linkage and carburetors can be adjusted to where they are not needed. If the surge spring does not help remove the surge adjustments can be made. Since it started after an overhaul I suspect it could be in the carburetor rather than linkage from the governor.
Bookman
08-24-2017 17:47:14
Nope. Will that do that job? I will check with local AGRO dealer tomorrow and see if they have it or can get it. Thanks
old
08-24-2017 21:00:42
 Re: Allis Chalmers C Surging in reply to Bookman, 08-24-2017 17:47:14
Well it is the anti surge spring and yes that is what it is made for so yes good chance it will stop your problem
bookman
08-25-2017 07:54:18
 Re: Allis Chalmers C Surging in reply to old, 08-24-2017 21:00:42
Reading and looking at the parts manual. Do I need to take the manifold off and put the spring between the manifold and the gasket or what? I did find the hole in the governor rod from the carb forward. Thanks
old
08-25-2017 08:05:18
 Re: Allis Chalmers C Surging in reply to bookman, 08-25-2017 07:54:18
One of the forward manifold studs should be longer and it is that way to be able to hook the spring to it. It just hooks over the end of the stud and spring pressure keeps it there
Bookman
08-24-2017 17:47:04
Nope. Will that do that job? I will check with local AGRO dealer tomorrow and see if they have it or can get it. THanks
old
08-24-2017 16:00:20
Do you have the spring on the carb/gov linkage that hooks to the manifold?? It is an anti surging spring made to stop that
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
Latest Ad: 3pt hitch for ford 3930 [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
