Re: Fuel System Problems
Brian
07-07-2000 13:35:33
A bad condenser will make it run bad. Before tearing the carb apart, check the ignition first. There is far less that can go wrong in the carb than in the the ignition. Look over the points and dist cap, and wires. Fouled plugs also cause trouble. Through trial and error, I have found AC Delco 45 plugs to be the best in this application. An inline fuel filter can't hurt. Make sure the ignition is up to snuff first. Brian
