Re: Model B Rear Wheel Clips
Dick L
07-07-2000 07:05:07
Do you have two per wheel or four? I bought a B from a guy that couldn't get them tight and he had put the solid ones opposit each other and the adjustable lugs opposit each other. The one C I bought had four adjustable lugs per wheel. I also have a C out back that has shimms under the lugs.
Rick in NC
07-07-2000 08:09:18
 Re: Re: Model B Rear Wheel Clips in reply to Dick L, 07-07-2000 07:05:07
Dick,
I have 2 adjustable ones per wheel. I have the two fixed ones beside each other with one of these engaging the driving lugs on the rim. The two eccentrics are opposite these.
What I may do is find another eccentric clip and bolt and put a third one on the wheel to see if that will help.
Thanks for the idea.
Sandy Lake Implement
07-09-2000 16:49:11
 Re: Re: Re: Model B Rear Wheel Clips in reply to Rick in NC, 07-07-2000 08:09:18
Original issue was 2 eccentrics per wheel. More can be added as needed. We stock them
& may have some used ones.
