Company Logo Shop Now
transmission fluid on a C model
racsan
06-01-2017 10:51:26
recently got a reasonable seal on a a/c C model with a 72" woods mower, like any older machine it needs some attention, one thing i noticed is a noise in neutal with the clutch released, its probapby there when driving too, but cant hear it over the engine. im thinking its either a input shaft or countershaft bearing. i read somewhere that the trans oil is 20wt motor oil, im wondering if it would be better (and buy me some time) to run a 80/90 in the trans like the final drives have. im not going to be using the hydraulic lift, just the pto for the mower, good/bad idea? i realize at some point the bearing will go regardless, but if a 80/90 would be better and let it make it a last a little longer-why not?
racsan
06-08-2017 21:05:14
 Re: transmission fluid on a C model in reply to racsan, 06-01-2017 10:51:26
Quoting Removed, click Modern View to see[URL=http://s1160.photobucket.com/user/dbird1970/media/Mobile%20Uploads/IMG_20170608_105459_zpszyb5oih2.jpg.html]third party image[/URL]
racsan
06-03-2017 15:36:27
[URL=http://s1160.photobucket.com/user/dbird1970/media/Mobile%20Uploads/IMG950321_zps7htg30zg.png.html]third party image[/URL]
The front tires are temporary spares. I have the original rims, no tires on them though. Has some sort of cast iron weights on the inside of the rear rims
racsan
06-03-2017 14:56:05
Got a 5 gal bucket of 303 yesterday at rural king, not sure what it ran, got quite a few things for the new toy, oil, filter, orc, exhaust flapper for the stack, a I & T book (more like a panphet on that series) I just might try fabbing up a 3 point someday, for now just going to get done whats needed and enjoy not spending forever mowing the lawn. I'll get a picture up sometime later.
old
06-03-2017 18:46:37
 Re: transmission fluid on a C model in reply to racsan, 06-03-2017 14:56:05
My C has a front lift for things like a snow plow which i made form pictures one of the guys on here sent me plus to off set the weight up front I built a 3 point on it
Aaron SEIA
06-02-2017 03:46:05
The hyd pump is running as long as this PTO is engaged. I would run the 303 fluid.
AaronSEIA
racsan
06-01-2017 21:05:43
It has a hydraulic lift but cylinder isnt hooked up. I dont plan on ever using it, just going to be a mower. Saw rural king has "303" fluid, might consider that.
old
06-02-2017 13:57:01
 Re: transmission fluid on a C model in reply to racsan, 06-01-2017 21:05:43
If you have an Orschen's farm and home place around if you watch you can find that 303UTF on sale for $19.95 regular price is $24.95
4wdtom
06-01-2017 15:04:27
You can use 990 weight unless you have hydraulics. If you have hydraulics you have to use 20 weight or a "tractor lube".
bg/mo
06-01-2017 13:37:12
could be coupling on shaft from clutch to input on transmission those splines wear alot
old
06-01-2017 13:06:24
Not uncommon for them to be a bit noisiey so good chance you have no problems any how. My self I run the 303 UTF in my C and have for decades and yes mine makes some noise also
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: I have A narrow front end from 65 Massey and also a front guard for a 65 Massey call or e-mail for price. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
