Company Logo Shop Now
Allis b and c questions for allis experts
jocco
05-24-2017 06:47:08
I am not a regular here on the AC forum. I am looking at some b and c tractors and was wondering if the only big difference is the front end? Could any of you tell me if motor, tranny, rear end etc. is the same? Thanks much.
steve(ill)
05-24-2017 15:49:17
 Re: Allis b and c questions for allis experts in reply to jocco, 05-24-2017 06:47:08
The tractors B and C , use the same radiator, fan, hood, engine, clutch, transmission, bevel gear, and pto housing...the radiator shroud is cut out on the C for the second steering gear box drive.... the C final drives are 6 inches wider on each side or 12 inches total tractor width.. Internal parts can not be mixed.. but you can remove a final drive case and install the entire unit off the other tractor. The tractors use the same rims and tires.. the wheel HUB is different as the final drive bull axle is different. The steering boxes are different and not interchangeable. The steering box on a B drives directly to the left side wheel king pin... the C steering box drives to a second gear box in front of the radiator as most C tractors were narrow front ends.. All B tractors were wide front ends. C could be either.
Traditional Farmer
05-24-2017 13:33:21
B's had 3 front end options over the years,C also had 3 front end options all different from the B ones.As said the C final drives are wider,C always had the bolt on rear hubs the B changed to the same hub during the later part of production.B first had the BE engine but changed over to the CE engine when the C went into production.C has a wider draw bar.Both had several fender variations over the years.C has a different grill to make room for the steering arm.C and B steering boxes turn opposite each other.B had a at least 4 front wheel options over the years,have seen 3 different front wheels on a C
ed in cny
05-24-2017 12:36:44
I'v seen B's with C rear ends and the other way around so I know they change out. It's likely they change at the torque tube. Front ends as well can inter change but not everything. Steering boxes are different as is the way the work. So there are some things that work some things that don't. Good little tractor and hard working.
old
05-24-2017 09:05:43
The engine is the same on both but as the others have said a few other things are different
Jocco
05-24-2017 12:38:56
 Re: Allis b and c questions for allis experts in reply to old, 05-24-2017 09:05:43
Old can you tell me anymore?
old
05-24-2017 12:45:28
 Re: Allis b and c questions for allis experts in reply to Jocco, 05-24-2017 12:38:56
Like what?? Most of the sheet metal is the same but things like the steering box is different. I.E. if you try to put a wide front form a B on a C you will turn the steering wheel left to go right. If I remember right the transmission are not the same either. They will swap out but the gear ratios are different.
Jocco
05-24-2017 16:07:57
 Re: Allis b and c questions for allis experts in reply to old, 05-24-2017 12:45:28
Ok with others posting I am getting my answers I always wanted a c but not a b. Been around them some but no expert. Would really like an rc.
Traditional Farmer
05-24-2017 19:51:21
 Re: Allis b and c questions for allis experts in reply to Jocco, 05-24-2017 16:07:57
Wish you'd of been around me awhile back I had a hard time getting $400 for a C that ran and operated good.
Jocco
05-25-2017 03:42:15
 Re: Allis b and c questions for allis experts in reply to Traditional Farmer, 05-24-2017 19:51:21
Sorry about that that was an opportunity.
old
05-24-2017 19:40:42
I have 4 C on my place 2 are runners and 2 are parts machines. I did have a B many years ago but some one borrowed it with out permission and left it in the creek and it did not swim well
JMS/.MN
05-24-2017 08:55:33
They are different on each end. B typically has an arched front axle, and is made to straddle one row. Rear end is narrower than the C. C is a two row tractor.
4wdtom
05-24-2017 07:21:43
The C is a two row tractor and the B a one row. The rear end of the C is wider, and if a wide front the front axle will be wider.
Aaron SEIA
05-24-2017 07:21:24
The final drives on a C sit wider. B was only narrow front but a C could be had with a wide front. Engine and tranny are the same.
AaronSEIA
chalmersbob(pa)
05-26-2017 23:57:32
 Re: Allis b and c questions for allis experts in reply to Aaron SEIA, 05-24-2017 07:21:24
The B only came with a WIDE front axle, non-adjustable or adjustable.Adjustable wide fronts were special orders and came with the adjustable rearwheels like the C used.
The C came with a single front wheel, tricycle front or wide front.
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
Latest Ad: 3 point drag arm for 420 HD crawler right side [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
