Company Logo Shop Now
Allis Chalmers WC mag shut off pull rod
alliskid
05-22-2017 17:59:12
I purchased a 1943 WC steel rearend which I'm assuming is very low hours still 4 inch bore flat top pistons and the shifter is smooth. The tractor at one time had a picker mounted on it. It has a pull rod that runs down to the mag. wasn't sure if since it had a picker if that's why they used the pull rod to ground the mag out with out having to take the picker shields off? How long was that used or was it an option? And is the mag specifically built for that application? Thanks everyone.
acadam20
05-23-2017 07:00:59
 Re: Allis Chalmers WC mag shut off pull rod in reply to alliskid, 05-22-2017 17:59:12
The mag was set up different if you had that shut off rod. It is a little flap that basically pulls back and hits the ground rod. It was also on the back side toward the block and not in the front.
JMS/.MN
05-22-2017 20:49:11
Our picker had shields...the one on the left side had a sliding door near the carb, so you could set the choke. Right side shield was solid. They would interchange from one side to the other. I suppose if you had a choke rod at the steering wheel, you could use the sliding door shield on the right side and check engine oil?
Butch(oh)
05-22-2017 18:18:13
That is the way all of the later ones were built. The switch was mounted on the magneto externally ad operated by the rod. Not many survived as dampness would cause the switch to ground the mag when it wasn't supposed to so they were removed and a wire was run to a switch near the operator.
alliskid
05-22-2017 19:21:19
 Re: Allis Chalmers WC mag shut off pull rod in reply to Butch(oh), 05-22-2017 18:18:13
Thanks Butch! That would kinda fit with the rest of the tractor being low hour's.
Latest Ad: 77O GAS ENGINE WITH 1550 OVER SIZE KIT, LOW HOURS, COMPLETE SET UP AND EXTRAS. CALL FOR DETAILS OR PICTURES. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
