Company Logo Shop Now
Re: WD45.....possible head damage
Phil Auten (TX)
06-28-2000 05:29:06
Ken,
If the water in the oil is really just a little, I suspect you have a bottom seal leaking on one sleeve. A head gasket or ckacked head/block will usually leak quite a bit more than the o-rings. You may want to try an application of a stop leak type product before spending a lot of time disassembling the tractor. The best way to tell is to pull the head and have it magnafluxed for cracks. Have it checked for warping too, while it's off. If it isn't cracked, and the head is warped, but fixable, it will probably be the problem. You will need to install a new head gasket anyway after pulling the head. The A-C blocks for the WC, WD and WD-45 were all prone to cracking between the cylinder bores on the top surface of the block. This is not a problem as the cracks are sealed by the head gasket. If the block is cracked between the bottoms of the bores, then you have a real problem that will require a replacement block, welding and machining the old block or some other method of repairing the old block.
Good luck,
Phil
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
