Company Logo (800) 853-2651 Shop Now
A-C Dual Fuel
GaryInKS
03-03-2017 18:55:42
Does anyone know anything about an AC dual fuel tractor?It has a propane tank and a gas tank , it looks like a WD -45 but I am not sure, any idea of the value? it looks like it is in good condition.
X-Y switch
03-06-2017 17:48:46
 Re: A-C Dual Fuel in reply to GaryInKS, 03-03-2017 18:55:42
When I was a kid, about 65 years ago, a friend of my Dads was running styled WCs on propane, don't know if they were dual fuel but seemed to run ok on propane.
Lon(MN)
03-06-2017 16:38:54
Here is one.
Bob Bancroft
03-04-2017 02:21:38
Never too old to learn--just looking at tractordata.com, I see three compression ratios listed for the WD45 226 engine. The common gas, a lower ratio for "tractor fuel"(I suppose the true dual fuel-start on gas run on distillate) and a higher ratio for the LP model. I assumed the gas tank was just used on the WD45 LP as a dummy to hold the hood. Probably cheaper than coming up with something else.
Used to be lots of WD45's around. No LP's here. Very few diesels.
JMS/.MN
03-03-2017 23:52:58
LP WD45 had a front mount LP tank that utilized the mounted cultivator brackets- the square cutouts that were referred to. They mount on the front of the C-channel frame. You could switch from one fuel to the other.
Jerry Coulter
03-04-2017 05:24:12
 Re: A-C Dual Fuel in reply to JMS/.MN, 03-03-2017 23:52:58
Because of the higher compression ratio, ethyl gasoline was to be used, not regular. This was a factory setup, not a conversion.
Tramway Guy
03-03-2017 19:49:11
The factory LP tank mounts had a square cutout for a front mounted cultivator.
jaden
03-03-2017 19:22:53
When I was a kid, a neighbor had a WD factory gas with a LP conversion. The tank was mounted in front of the radiator.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: good hydraulic unit for JD 50/520/530 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
