Company Logo Shop Now
D17 distributor rebuild
mikebol250
02-20-2017 17:41:21
I'm thinking of rebuilding my D 17 distributor there is some wobble in the shaft. Is this a complicated job? The shaft bushing and shims seem straight forward enough. Any advice would be appreciated on this rebuild.
Mike [/b]
mikebol250
02-21-2017 17:18:10
 Re: D17 distributor rebuild in reply to mikebol250, 02-20-2017 17:41:21
I'll give it a try .
Thank you
Mike
4wdtom
02-21-2017 06:45:30
The two Delco Remy distributors I have recently rebuilt were easy enough after getting the pin out that holds the drive gear on. I ended up carefully drilling it out I think, but I might have carefully filed off the peened over head and pressed it out. I do remember making a skinny support to hold the gear between the teeth and the distributor casting. This part I put in a drill press vise which held it upright under the arbor press. I do remember making a new pin on the lathe to a light press fit and carefully peening the ends when installing it. It seems like I do remember drilling a hole in the support block (a piece of steel mentioned above with a U shape hole in one end to support the gear when working on it in the press) to accept the pin as it was pressed out so maybe I did press it out. Anyway, the easy part is pressing out the old bushing and pressing in a new one. The two I did had porous bronze bushings and a 1/8"npt plug in the side of the distributor to oil the bushing. I pumped in a few squirts of oil after pressing in the bushing.
Today's Featured Article - ... [Read Article]
Latest Ad: 3 JD 6600 d combines 1 w 329 1 w 404 Turbo 1w 404 non Turbo believed to be good motors also 2 JD platforms and 643 ch posting for friend call for details. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
