Company Logo Shop Now
Allis B C CA, cylinder heads
Dustyah
01-29-2017 18:53:49
Found a guy parting out allis tractors near me, I have a 1945 B, will an ac c or ca cylinder head bolt on, perhaps give me more power, just a thought, thanks. Dusty
Dick L
01-30-2017 04:38:28
 Re: Allis B C CA, cylinder heads in reply to Dustyah, 01-29-2017 18:53:49
There is a difference internally in the casting. I found this when porting the different heads.
I have not tried to trace which is which as far as years. I just look in the ports when building one for easy flow.
Your CA head can be made to look and work like the one in the picture. It has been modified for smb Chevy valves.
third party image
third party image
third party image
third party image
nl00sb
01-29-2017 22:32:27
U can mill the head down up to .125 off to up the compression a little and gasket match the ports on it
Dick L
01-30-2017 06:31:19
 Re: Allis B C CA, cylinder heads in reply to nl00sb, 01-29-2017 22:32:27
I mill most of them up to .150 and have one I used in pulling that I took .200. At .200 the water jacket is thinner than I like and would do another one that far. It didn't cause a problem for me. The water jacket on these head are thicker than most. I sliced a head up to see what problems I might run into. Just information for those that like to spend money.
third party image
third party image
Dick L
01-30-2017 06:36:15
 Re: Allis B C CA, cylinder heads in reply to Dick L, 01-30-2017 06:31:19
More information: When you remove .125, which is a good mill amount, or .150 you need to put an equal spacer under the rocker arm stands.
nl00sb
01-30-2017 13:00:37
 Re: Allis B C CA, cylinder heads in reply to Dick L, 01-30-2017 06:36:15
Dick l did I read at one time u did a 1/2" stroked Motor in one of these if so did u find an offset grind set up or did u have to do a welded crank ? Thanks for commenting on this fellas post I like reading your comments
Dick L
01-30-2017 15:27:10
 Re: Allis B C CA, cylinder heads in reply to nl00sb, 01-30-2017 13:00:37
I used the crankshaft from a D-15 series one. I turned the mains wider and within .010 of standard diameter and width. I took it to a engine shop to be ground and where they welded the rod journals and ground them back to standard offset to the 4 inch stroke. I did two. I put one in a C and one in a B.
old
01-29-2017 19:04:53
B, C, and CA all are the same engine other then the very early B so no more power but is a direct bolt on
Copyright © 1997-2020 Yesterday's Tractor Co.
