Company Logo Shop Now
out of time
tbartels
01-19-2017 16:28:10
i have a 1953 wd-45 that I believe is a 180 degrees out on the timing can anyone tell me the steps I need to fix this . thanks in advance
Traditional Farmer
01-20-2017 06:07:47
 Re: out of time in reply to tbartels, 01-19-2017 16:28:10
If its the dist out of time the simple way to get it right is to just keep moving the wires around the top of the the dist one hole at a time and then cranking to see if it fires up.
Aaron SEIA
01-20-2017 03:56:06
Assuming the dist wires are wrong...bring #1 (closest to the radiator) up to top dead center compression. Pull the plugs and use your thumb over the hole. When air is rushing out, you are on compression. Pull dist cap and align rotor tab with the closest plug tab. Put wires on in firing order. Agree with others, they do not just fall 180 out of time. Need more info to give better help.
AaronSEIA
ramblineagle
01-19-2017 19:09:21
call your fatherinlaw
David G
01-19-2017 18:31:25
I would agree with Old.
Engines do not just get 180 out of time by themselves, please tell the whole story.
old
01-19-2017 18:29:25
Out of time as in cam or distributor?? Hard to help with out more info
Latest Ad: Farmall 450 400 factory wide front End, nice tight front end, no welds, 1250 obo [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
