Company Logo (800) 853-2651 Shop Now
Allis Chalmers d17 puller
Shadetree21
12-24-2016 10:41:37
I have been doing a lot of research on how to increase my horsepower and slow down my gear in my d17 with a 262 engine. I was also trying to figure out if the 6 cylinder diesel would be a better option. Any ideas?
DrAllis
12-27-2016 10:26:17
 Re: Allis Chalmers d17 puller in reply to Shadetree21, 12-24-2016 10:41:37
You could swap the intermediate gears ahead of the hand clutch for D-19 gears and that would slow down low range about 12 to 15%. That's the only slower gear combination I know of. Sounds like you need a 100 HP D-17 puller engine.
Shadetree21
12-25-2016 08:10:23
Well I have 2 d19s one gas one diesel I have 2 170s both diesel and 3 d17. If it's possible in the rules where I pull I want to put the d19 gas which I believe is the 262 in it. But if I have to use a stock block i'd like to know how to build one
Shadetree21
12-25-2016 07:38:04
I pull dead weight with mine for 5 years and there is no weight class. I weight up to about 16,000 and pull but in the past couple years I haven't been able to keep up with everyone else so I need to change something
DrAllis
12-25-2016 07:10:15
Mr. Shadetree21....Why do you want to cut your speeds in half?? I happen to pull a D-17(for 30 years) and always use 2nd and 3rd gears. what do you know that I don't understand ?? If you're thinking of pulling it in 7000 lbs and up....DON"T.....you're wasting your time.
Shadetree21
12-24-2016 11:05:42
I want to slow down the gears in the transmission is like to cut the speed in half if possible. Thank you for the info
DrAllis
12-24-2016 11:02:07
Don't know what you're thinking about when it comes to slower gears?? Any 262 gas engine can/will always make more HP than any 262 diesel UNLESS you turbocharge the diesel. That 262 gas can easily have a 190XTG or G combine carb added to it and raise the PTO HP up to probably 80 ish or so, while the non turbo diesel is 51 HP. Also, some places may not even allow you to compete with a 6 cylinder as engine in a D-17...not stock. A turbo diesel in a D-17 isn't stock either.
Skyhighballoon(MO)
12-24-2016 15:03:37
 Re: Allis Chalmers d17 puller in reply to DrAllis, 12-24-2016 11:02:07
Here in central MO, a guy I knew (since passed away) used the fact that Allis made a cotton picker with a 262 gas engine and was based on the D17 tractor chassis to qualify his pulling D17 with a 262 in for the classes he ran in.
D beatty
12-25-2016 01:46:54
 Re: Allis Chalmers d17 puller in reply to Skyhighballoon(MO), 12-24-2016 15:03:37
The D 17 tractor was built from 1957 - 1967 ( 226 4 cylinder gas). Allis chalmers did not put a 262 gas engine into a cotton picker until 1982.
Bob Bancroft
12-25-2016 06:15:51
 Re: Allis Chalmers d17 puller in reply to D beatty, 12-25-2016 01:46:54
Norm Swinford's book indicates 1982 was the last year of cotton picker production. Indeed, AC was near death at that point. By then, they had switched from the 262 to the 301, and finally the four cylinder/turbocharged 200 engine. He doesn't give a date, but indeed states that the 622 pickers were built over a D17 frame, with basically, either D19 engine. Also stated is that converting these power units back to a tractor was frowned upon, for obvious reasons.
D beatty
12-25-2016 07:52:30
 Re: Allis Chalmers d17 puller in reply to Bob Bancroft, 12-25-2016 06:15:51
The point is Allis Chalmers never built or offered a 6 cylinder gasoline engine for the whole production run of the D17 (1957 - 1967).
Bob Bancroft
12-25-2016 10:46:16
 Re: Allis Chalmers d17 puller in reply to D beatty, 12-25-2016 07:52:30
I doubt anyone disagrees with that statement. My point is that the statement about 1982 is way off.
D beatty
12-25-2016 11:39:45
 Re: Allis Chalmers d17 puller in reply to Bob Bancroft, 12-25-2016 10:46:16
Allis Chalmers history is screwy . I found an Allis site that states that the Allis chalmers cotton where built after 1982 under the name Agco Allis. I know Chalmers records are not right because they say that their mowers where built in the south when actually they were built in the LaPorte works as well as some cotton pickers. Allis Chalmers first square balers were said to be American built but where not. They where assembled in USA but came in sub assembled from over seas (England). The demise of Allis Chalmers was said to be unions fault but it was also just as much managements fault . Their management had problems.
D beatty
12-25-2016 01:32:40
He may have got away with it but a D17 was never offered with a 262 gas engine. The D 17 diesel did have a non turbo 6 cylinder 262 engine.
Today's Featured Article - Sunday Drives - by Cowboy. Summer was finally upon us here in Northern Maine. We have two types of industry up here, one being "Forestry" (Wood Products) and the other "Farming" (Potatoes). There is no shortage of farm tractors and equipment around here! I have been restoring old Farm Tractors for the past 6 years, and have found it easier and less expensive to hit all the auctions and purchase whole tractors for parts needed. My wife who works at a local school, and only has weekends and summers off, while on t ... [Read Article]
Latest Ad: WANTED looking for vintage Brake & Clutch riveting machine . Please provide pictures with details . Foot operated or ??? Please advise JJB [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
