Company Logo Shop Now
anything to be aware of when checking out a "B" a/
racsan
11-30-2016 19:47:39
looking at a 48 a/c-"B". has a underbelly mower on it, haven't heard it run yet but does turn over, steering box isn't too loose, seems a little sloppy when trans is in 2nd gear, tires good. any common problem areas to be aware of with this model? looks to have a magneto along with a electric starter.
old
12-01-2016 08:50:14
 Re: anything to be aware of when checking out a in reply to racsan, 11-30-2016 19:47:39
The B is a good little tractor but if run with the wrong oil filter for very long can have rod and main problems so oil pressure when running is important on them and being a low pressure system that get pressure by way of a back pressure filter is important.
4wdtom
12-01-2016 06:42:11
If you don't have a good shift lever boot on ACs water can get into the transmission if the tractor is out in the weather much. Check drain plug and see if any water is in trans/rear end.
Ted in NE-OH
11-30-2016 20:17:45
Looks for loose wheels on rear axles. The wheels if loose can wear the spline so bad that tightening is no longer effective (expensive fix).
Also on the mower, loosen the belt and then wiggle the mower blades up and down checking for worn spindles.
Latest Ad: Farmall 450 400 factory wide front End, nice tight front end, no welds, 1250 obo [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
