Re: 6 volt Allis CA
Grandad (MI)
06-21-2000 00:57:13
Use an 8 volt battery. It works with all your existing electrical parts just fine. If you use 12 volts you would have to change light bulbs and if you have a distributor ignition put a dropping resistor in circuit ahead of the coil.
Rick Davis
06-22-2000 05:19:49
 Re: Re: 6 volt Allis CA in reply to Grandad (MI), 06-21-2000 00:57:13
Make sure you are using the correct battery, the book states a minimum cranking power of 600 to 700 cranking power.
