Company Logo (800) 853-2651 Shop Now
Removing B Oil Pan Question
Tim in New York
11-13-2016 08:18:38
The oil pan gasket on my B was leaking, so I ordered a new one. Got all the bolts out of the pan, but I can't get it off the bottom of the engine. Do I need to remove the bolt that holds the axle to the frame to get the pan off?
Thanks,
Tim
Raptor44
11-24-2016 06:02:20
 Re: Removing B Oil Pan Question in reply to Tim in New York, 11-13-2016 08:18:38
Mine actually went on easier than getting it removed. Strange???
Dick L
11-15-2016 12:15:10
Years ago I put on a picture of two pans that I had taken off two different B's. Corner ways one was longer than the other. The longer one from one corner to the other I had to loosen the bolts about 1/2" so the front axle could be pried forward. The shorter pan corner to corner would rotate to miss the pivot bolt to drop down.
Tim in New York
11-17-2016 11:08:23
 Re: Removing B Oil Pan Question in reply to Dick L, 11-15-2016 12:15:10
I was able to wiggle the pan out after turning the wheels all the way to the right. I am not sure exactly why that helped, but it did. Now I just need to get it back on.
Tim
Raptor44
11-13-2016 12:22:08
Just turn the wheels all the way to the right and finesse it off. That should work. Im restoring a B now. I plan on removing the axle assembly to change front timing cover gasket and seal. I need to change my oil pickup at the same time. Good luck
Tim in New York
11-13-2016 17:44:19
 Re: Removing B Oil Pan Question in reply to Raptor44, 11-13-2016 12:22:08
OK - will give that a try.
Tim
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: want to buy open station platform and fenders for 4430 john deere, needs to be in good condition . [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
