Company Logo Shop Now
Allis Chalmers WD fuel Cap
SEKbob
11-06-2016 09:11:53
I've ask this before, but I'm still not sure.......Does my Allis Chalmers WD require a vented fuel cap?
cleddy
11-20-2016 06:10:29
 Re: Allis Chalmers WD fuel Cap in reply to SEKbob, 11-06-2016 09:11:53
third party image
third party image
third party image
This post is old so you are maybe moved on by now. I have a couple original caps and they do have a vent hole near the center inside and vent over to the side above the gasket. It would be an easy thing to miss or be pluged. Since they are old they may vent around the worn gasket to but there should be a vent hole. cleddy
allis dave
11-08-2016 06:08:47
If it's like my WD45 cap, it leaks enough that it doesn't need a vent hole!
SEKbob
11-10-2016 11:13:57
 Re: Allis Chalmers WD fuel Cap in reply to allis dave, 11-08-2016 06:08:47
I had to buy a new cap, so doesn't vent like my old cap
maxwell99
11-06-2016 21:26:13
Unless you have a dedicated vent for the fuel tank then I would say yes with a gravity fed fuel system you must have a vented cap,
SEKbob
11-10-2016 11:16:38
 Re: Allis Chalmers WD fuel Cap in reply to maxwell99, 11-06-2016 21:26:13
Any suggestions where I can find a vented cap. All the vented caps I've found do not mention that they will fit a WD. Tractor runs fine with the cap I have, but when I release the fuel cap it comes up into my hand. Too much pressure I believe.
D beatty
11-06-2016 10:03:35
third party image
third party image
If you have a cap like this they are not vented.
SEKbob
11-10-2016 11:18:22
 Re: Allis Chalmers WD fuel Cap in reply to D beatty, 11-06-2016 10:03:35
If I get this style of cap, where would you recommend drilling a hole. Don't want water getting into the tank
Ted in NE-OH
11-07-2016 14:54:19
but you can drill a small vent hole and it will work fine.
D beatty
11-07-2016 15:00:26
 Re: Allis Chalmers WD fuel Cap in reply to Ted in NE-OH, 11-07-2016 14:54:19
I pull my WD 45 and I drilled a small hole in cap like the one in picture.
SEKbob
11-10-2016 11:12:57
 Re: Allis Chalmers WD fuel Cap in reply to D beatty, 11-07-2016 15:00:26
I don't see a pic. Did I miss it?
D beatty
11-10-2016 13:08:34
 Re: Allis Chalmers WD fuel Cap in reply to SEKbob, 11-10-2016 11:12:57
If you look above I posted a picture of cap that fits a wd45.
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
Latest Ad: 3pt hitch for ford 3930 [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
