Desert Rancher
Howdy,
Not sure I'm in the right forum but I'm looking at a now defunct Henry TS 500 loader. The loader cylinders are all leaking, but the pump seems clean. Owner says the pump worked great. Was wondering what the loader specs were carry/lift capacities as well as the pressure/gals/min of the pump. Not sure if this is the pump that came with the loader. It does appear to be chain driven off the front shaft. It's kind of a round/bulbous, awkward looking thing. I did see some #'s stamped in diagonally across the front but didn't think they were model #'s. The #'s at the bottom of the rounded pump part are mostly worn away by a hose rubbing against them there. Any help would be appreciated
Thanks
Thanks
