Company Logo (800) 853-2651 Shop Now
Allis Chalmers C parts and hydraulics
bookman
10-07-2016 19:28:06
I am putting my 1942 Allis Chalmers C back together, and I am nearly done. However, I am not sure how the left hydraulic cylinder goes on. I get it on but it rests on the belt pulley when the hydraulic hose is one top, and it will not go on when I try the hydraulic hose on the bottom. Is there something that holds the two hydraulic cylinders up?
Then I have two pieces I do not know where they go. The are two L shapped pieces with one side about an inch long and the other side about two inches long. The side with two inches long has two holes in it. In the parts manual there is a picture of a hose guard (but it just has one hole in it) and perhaps that is what these pieces are, but I cannot determine how where they fasten to anything and how they protect the hydraulic hoses or maybe hold the hydraulic cylinders up.
There is probably something quite obvious that I am missing. But I need someone to point me in the right direction.
Thanks in advance.
Larry
bookman
10-17-2016 19:13:49
 Re: Allis Chalmers C parts and hydraulics in reply to bookman, 10-07-2016 19:28:06
Finally found some old pictures I took before taking the tractor apart. I did not have the seat mounted high enough. The two brackets fit below the rear of the seat. The hydraulic cylinders do not hit the seat that way. Plus I put a bar under the seat to hold the ends of the cylinders up.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: 4386 or 4586 IH [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
