Company Logo Shop Now
B Radiator Removal- how?
Tim in New York
10-01-2016 15:58:15
I have to replace the water pump on my B. Is there a trick to getting the front nose cone and grille off? I pulled all the bolts I could find and it will wiggle some, but does not seem to want to come off. Do I need to unhook the radiator hoses and pull the radiator and the shroud off together? I don't want to force something and break it. The bottom of the nose piece below the grille is banged up pretty badly.
Thanks,
Tim
Tim in New York
10-03-2016 09:24:44
 Re: B Radiator Removal- how? in reply to Tim in New York, 10-01-2016 15:58:15
Thanks everyone - it took just a couple of whacks with the rubber mallet to get it off.
Tim
Chalmersbob(Pa)
10-01-2016 19:27:42
after removing all of the bolts, pull the grille out at the bottom and this will allow you to slide it up to clear the radiator cap. Then just pull it off. The bolts under the grille are 1/2" bolts that act as a stop for the front axle. LOL Bob
Tim in New York
10-02-2016 07:31:55
 Re: B Radiator Removal- how? in reply to Chalmersbob(Pa), 10-01-2016 19:27:42
Thank you everyone - will give it a try today.
Tim
4wdtom
10-01-2016 19:08:33
I have done it by spring the tip of the cowling over the radiator fill which isn't easy, then sliding it forward. You need to take off the hood first to make it easier to work on both the grill/ cowling and water pump. Put a new belt on so you won't have to do it later.
old
10-01-2016 16:12:11
Been a long time since I have done it so I may not be correct but yes I thing you need to pull the grill and radiator s a unit Which also means pulling the hood off
Tim in New York
10-01-2016 18:11:55
 Re: B Radiator Removal- how? in reply to old, 10-01-2016 16:12:11
Thanks Old - got the hood off already.
Today's Featured Article - ... [Read Article]
Latest Ad: 3 JD 6600 d combines 1 w 329 1 w 404 Turbo 1w 404 non Turbo believed to be good motors also 2 JD platforms and 643 ch posting for friend call for details. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
