Company Logo Shop Now
D14 lift arm problem
krieg1952
09-21-2016 19:05:16
I have a D14 and the lift arms will not go down on their own. Any help will be appreciated.
funky_g00
09-22-2016 18:38:03
 Re: D14 lift arm problem in reply to krieg1952, 09-21-2016 19:05:16
If you have both levers in the correct down postion. The arms should come down with relative ease, all be it very slowly. I am guessing that you have some crud in the pump and/or valve assembly and your return valve/check ball is sticking or it is out of adjustment. If you have a manual it should tell where it is located and whether or not it is adjustable.
cole in mo.
09-22-2016 16:50:53
On my 14 if the arms are raised all the way up, with both levers pulled down, the arms won't move until I force them a little, then they drift down on there own, always will when something is hooked to them.
krieg1952
09-22-2016 15:15:10
Should the arms, when in the up position, be so "stiff" that I can't pull them down by hand? If so, how do I hook up to the plow?
krieg1952
09-22-2016 15:12:55
DrAllis
09-22-2016 07:43:33
Both hydraulic levers to the left of the steering wheel need to be down. This means horizontal or more. In the case of the longer lever, below horizontal is the lowering position. When the arms are down, do they raise up when the engine is running?? It is somewhat normal to have to stand on the arms to get them to actually go down from clear up. Not all lift arms will drop by gravity.
Latest Ad: 77O GAS ENGINE WITH 1550 OVER SIZE KIT, LOW HOURS, COMPLETE SET UP AND EXTRAS. CALL FOR DETAILS OR PICTURES. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
