D17 hydraulics
dhermesc
How many drain plugs are there on the trans hydraulic system - we found two. We drained and replaced the filter. The manual says it will hold 22 quarts - we only got 19 quarts and it is very over filled.
WHAT AGE/SERIES OF TRACTOR??? Three (3) drain plugs....one directly down from the fuel tank.......one directly down from the PTO lever.......one directly down from the seat suspension.......all take 1 1/8" wrench. There will be two or three fill ports/dipsticks depending on tractor age/series.
D17 Series IV. We missed the one under the seat - I assumed that one was for the 80/90 gear oil.
So what issues do you run into with the hydraulic reservoir over filled?
