7060 dripping water in the cab
cjrpr
my cab on 7060 black belly is dripping water from air conditioner condenser inside from the ceiling. are there drain hoses underneath the cab that I can blow air pressure in to clean out? if so where are the located? or how is it supposed to drain? I don't see anything under the cab. thanks for any help.
I don't know, but I would guess your drain hoses just don't reach to the bottom of the corner posts. I would also guess you might need to get right into the AC pan and clean it.
