Company Logo Shop Now
2 prong Voltage Regulator Part Number
RTR
08-08-2016 18:30:29
Guys, I have a 1952 Allis Chalmers CA with the original 6 volt system. It has what I think is a voltage regulator that has 2 electrical prongs. It is mounted on the generator. I need to get a new one TOMORROW so I can get the tractor back together. Would anyone know where I can get one? If so, the part number.....a napa or o'Reilly part number would be great as that is where I will go.
John T
08-09-2016 05:22:18
 Re: 2 prong Voltage Regulator Part Number in reply to RTR, 08-08-2016 18:30:29
If there's only 2 terminals, Bat and GEN/ARM its a Cutout Relay instead of a full fledged 3 or 4 terminal Voltage Regulator. Be sure and get one for 6 volts and suitable for your ground (Pos or Neg). If you cant get one you could get by with a 30 amp Diode instead available at electronics suppliers, wire at the correct Polarity, one lead to Battery/Ammeter wire, the other to the Gennys ARM post.
John T
RTR
08-08-2016 20:12:20
The one that's on the tractor looks original. The prongs are side by side, not on opposite ends like the one you pictured
JoeM(GA)
08-08-2016 18:50:01
A two prong should be a "cut out" not a voltage regulator, every regulator I have seen is 3 or 4 prongs
NAPA #s68375
third party image
JoeM(GA)
08-08-2016 18:53:12
 Re: 2 prong Voltage Regulator Part Number in reply to JoeM(GA), 08-08-2016 18:50:01
this site also sells the cut out in their parts section - Voltage Cutout 6 Volt Part Number 574459
$28.37
Latest Ad: 1968 John Deere 3020 orchard diesel, needs full restoration. Asking 8500 or best offer. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
