Company Logo Shop Now
WD 50 AC
wellmax99
08-07-2016 21:01:39
third party image
This tractor is advertised as a WD50
did AC ever make a WD50???????
maxwell99
08-08-2016 16:24:25
 Re: WD 50 AC in reply to wellmax99, 08-07-2016 21:01:39
Thanks for your reply's
I did not think AC made a WD50 , but you never know, many test models might have been tried,
4wdtom
08-08-2016 08:15:52
There was no WD-50. Look at the serial no. of the engine on the left side of the block, it will say start with 45 if it is a 45 engine. You can't really tell now as many WDs have had 45 cranks and kits installed to make them into 45s. The 45 block doesn't have the cover plate on the right side of the engine either, this is a about 1/8" thick plate the length of the block and maybe 5' high, easy to spot. Check the tractor serial no. on the back left side of the differential housing on the machined area behind the left brake area. Compare to serial no. list. A 45 will have a curved shift lever, but some WD did too. And the 45 had a curved seat bar, the WD had one with two straight sections and a bend between them. This one could be easy to change so it isn't a positive sign, just an indication. It is hard to tell from your picture, but it looks like the shift lever might be straight, a WD.
blue water massey
08-07-2016 21:03:23
yr 1950 would be my guess
Latest Ad: Looking for a gearbox casing that mounts to a Clinton Machine Company motor Model B764COC Serial# 2070576 part# 3801-C. It powered a Bolen 2 wheel walk behind tractor late 1940s model. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
