Company Logo Shop Now
Found a Nut I don't know where it goes
Brad W Wi
06-01-2016 07:48:54
Working up a food plot the other day I looked behind me and saw a nut on the ground. It's from my '51 WD. My Wd was painted 4 years ago and this nut was painted the same. Anyway, I can't find out where it goes. It takes a inch and a quarter wrench and it looks to be a one inch bolt that it would go on. It's also fine thread the way it looks. Any ideas where to look???????????? I've been looking and I can't find out where it would go. Of course it could be right in front of me. Thank you!!!!!!!!!!!!!
DrAllis
06-07-2016 12:54:17
 Re: Found a Nut I don't know where it goes in reply to Brad W Wi, 06-01-2016 07:48:54
WD or WD-45 Traction Booster coil springs do not have a large castellated nut on them. That's the D-14-15-17-19 series.
stu (ON)
06-02-2016 05:05:07
You still have drawbar control. You just don't have a Traction Booster gauge.
If you would like a homemade copy of original 1951 Operators Manual, just provide your e-mail address to me later.
stu (ON)
06-02-2016 02:27:13
Operators Manual also shows such a nut holding the belt pulley onto the pulley shaft.
JMS/.MN
06-01-2016 16:31:07
Tapered jam bolt is not fine thread. What about the spring under the center of the tractor....for traction booster? Does that have a fine threaded nut?
JoeM(GA)
06-01-2016 10:08:30
Hate to ask, but you did check your rear lug nuts?
D beatty
06-01-2016 23:32:58
 Re: Found a Nut I don't know where it goes in reply to JoeM(GA), 06-01-2016 10:08:30
Wheels are held on by lug bolts no nuts.
stu (ON)
06-01-2016 09:44:47
There is a large lock nut that secures the tapered jam bolt for the electric starter, and I believe the same for the belt pulley. Not near my '51, so cannot confirm the size.
Bob Bancroft
06-01-2016 08:21:23
Drawbar bail support stud?
Wide front pivot?
Brad W Wi
06-01-2016 13:55:14
 Re: Found a Nut I don't know where it goes in reply to Bob Bancroft, 06-01-2016 08:21:23
Not the pivot on the wide front end. But will check out the others tomorrow. It's over at my sugarbush a mile down the road. I'm home right now, but I'll be over there early in the A.M. I'll let you know and maybe their will be other ideas. Thanks to everyone so far.
D beatty
06-01-2016 23:49:02
 Re: Found a Nut I don't know where it goes in reply to Brad W Wi, 06-01-2016 13:55:14
If its not the nut on front end pivot then check snap coupler up under tractor. There is a large nut on the spring of traction booster coupler.
Brad W Wi
06-02-2016 04:03:09
 Re: Found a Nut I don't know where it goes in reply to D beatty, 06-01-2016 23:49:02
It's a WD not Wd45 so I don't have a traction booster. Heading over to the sugarbush soon, so I'll be checking things out. I'll let everyone know what I find.
jack a
06-07-2016 04:42:40
 Re: Found a Nut I don't know where it goes in reply to Brad W Wi, 06-02-2016 04:03:09
All WD and WD45 tractors have Traction Booster. Snap Coupler is just the hitching system. Most 45s have that and lots of WDs had it added later. Eitherway there is still a large nut in the area of the traction booster spring. Is there room for the axle pivot to have two fine threaded nuts.... double nutted and one fell off? Check for the jam nut on the set screw on the crank shaft pulley. I can't remember if they are fine threaded or not. Drawbar bail is supposed to have a slotted fine thread nut on each side that cotter pins are supposed to lock in place.
Brad W Wi
06-02-2016 15:44:18
I looked again today and checked out all the ideas sent. No luck. Wondering if it was a nut that was wedged in somewhere and painted with the tractor a few years back. I'm going to sit down with the parts manual and go page by page. I'm one of those that this will drive me nuts till I know if it's for the tractor or not.
Latest Ad: john deere 700 a hood for industrial tractor rare [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
