Company Logo Shop Now
180 allis chalmers transmission and pinion gears
rickymotorbrains
05-03-2016 14:18:24
does anyone know where I can get a pumpkin and pinion gears and main shaft around northern ky
Hurst
05-21-2016 06:15:09
 Re: 180 allis chalmers transmission and pinion gears in reply to rickymotorbrains, 05-03-2016 14:18:24
You might also try Mayer Farm Equipment. They are a little ways north of Cinci on I-71 if I remember correctly. Unfortunately many of the AGCO dealers that were originally Allis dealers in Kentucky have closed their doors, and a lot of their parts machines are now gone.
Hurst
Jim Phelps
05-04-2016 06:09:26
I cannot say about northern KY but there is a place in Iverington, KY called Frymeres that has been able to get parts for me so far.
rickymotorbrains
05-09-2016 18:27:41
 Re: 180 allis chalmers transmission and pinion gears in reply to Jim Phelps, 05-04-2016 06:09:26
would you no the number for them
DrAllis
05-03-2016 14:56:47
180-185-190's pretty much the same diff carrier. Make sure you get the correct spline count on the side gears.
rickymotorbrains
05-03-2016 15:12:13
 Re: 180 allis chalmers transmission and pinion gears in reply to DrAllis, 05-03-2016 14:56:47
yes that where im having the problem mine has the fine spline
Kabat
05-03-2016 14:35:24
In south central Illinois there are 2 salvage yards with a lot of Allis Chalmers. Cook Tractor in Germantown and also Northside Salvage in Redbud Illinois.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
