Company Logo (800) 853-2651 Shop Now
Motor oil choice
Buggy97
04-22-2016 14:38:59
What motor oil do you guys prefer for a 1943 model C? Weight? Detergent or non ?
Mark - IN.
04-28-2016 19:37:22
 Re: Motor oil choice in reply to Buggy97, 04-22-2016 14:38:59
I'd be very careful about that. I picked up an old B back about 2004 and used it only for mowing with a Wood belly. Not knowing its history, changed the oil every year and used straight 40 non-detergent because although clean inside are nice, I'm assuming might have been non-detergent its whole life. A couple, maybe three years ago I took a chance and moved to straight 40 detergent, changed every year, all looked OK. When I get home this weekend, I start its rebuild. For years and years and years, never had a problem. A couple few years ago, made the change and it might be a coincidence, but the whole rebuild kit and shipping from here at YT to my home, a little over $600. When I get done I hope I did it justice after maybe having done it an injustice. May as well look at a clutch while I'm in there.
Good luck, be careful.
Mark
thdrduck
04-27-2016 11:49:37
Quoting Removed, click Modern View to see Agreed. I would pull the plug, let her drain over night, replace the plug, remove the spark plugs and dump 1 gallon of diesel fuel in the crank. Put it in high gear and tow it around for a bit, drain, refill and repeat until the diesel comes out clean then change the filter and fill with your favorite multi grade oil. Seems to remove 70, 80 or 90 years worth of sludge without hurting anything. I'm sure it's wrong... but it works for me.
NEKS
04-26-2016 16:48:55
In the 80's talked to a major oil company rep. and he said that non-detergent oil should not even be sold anymore. I have to agree with wgm.
Aaron SEIA
04-24-2016 04:50:55
Using non detergent in a dirty engine is asking for an overhaul. If you don't know how much gunk is built up in it over the years, you will soon find out when the non detergent cleans the block and sends it through the crank bearings. If the engine is clean inside, then I would agree.
AaronSEIA
maxwell99
04-22-2016 17:33:02
If you know nothing about the past motor maintence,
I believe I would go with 30 weight non detergent oil, that is the oil that was used back in the day,
Some of the new detergent oils have great cleaning packages, will start cleaning out the built up sludge in the old engine and run it through your oil passages stopping them up, ruining your engine,
After you run the engine a few weeks, you might change the oil again, note how black the oil is,
After the second oil change I would just drive it and change it again next year,
Just my two cents!
Always have the engine at operating temperature when you drain the oil,
wgm
04-23-2016 15:31:59
 Re: Motor oil choice in reply to maxwell99, 04-22-2016 17:33:02
Using non detergent oil in any engine should be considered abuse.
FastFarmall
04-23-2016 18:18:32
 Re: Motor oil choice in reply to wgm, 04-23-2016 15:31:59
I agree WGM, but the good thing the newer fuels burn cleaner !
Ralphwd45
04-22-2016 16:30:44
I use 15-40 in most things, as I buy the Dello400, for the diesels, and we rarely get down to 20 deg here on the left coast. I like the 5 gallon cans, for a little better price.
Aaron SEIA
04-22-2016 16:13:45
I run 10w30 in everything. If it hasn't been apart in a while, you might want to stay non detergent. The detergent stuff can clean the block and send the crap through the bearings.
AaronSEIA
mattwillson
04-22-2016 15:31:19
Anything clean wet and slippery is fine. For the old stuff 15w40 is a good option. Unless it's an IH gaspot which requires low ash 30 so the valves don't burn up....anything slippery is fine
old
04-22-2016 15:01:30
I run the same thing in every thing I have other them my JD-B I use O'Reilly's brand 20W-50. Do not know for sure any more but at one time that oil was the same as Valvoline but been told be a couple people on here that is no longer so
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
