Company Logo (800) 853-2651 Shop Now
d-17 rebuild- Do rod bolts need to be replaced???
Ramp;W
04-13-2016 18:35:31
i am doing a full out of frame engine rebuild on a d-17 for a customer. another mechanic told me that the rod bolts need to be replaced . is this true? if so where should i get them from ? NAPA or an AGCO dealer? he said that after about 50 hours the rods come through the block...
Aaron SEIA
04-15-2016 04:13:32
 Re: d-17 rebuild- Do rod bolts need to be replaced??? in reply to Ramp;W, 04-13-2016 18:35:31
Make sure you follow the directions on getting the piston pins and rods in the right spot on the piston. The do NOT center in the piston. The factory and I&T manuals cover the technique for doing it right. Last engine I did came with paperwork on it as well. Do it wrong and the piston pins will carve a groove in your sleeve. If they'll even fit in.
AaronSEIA
DrAllis
04-13-2016 19:20:49
No. Old rod bolts are fine. If this is your first D-17 gas engine OH, you'd better be made aware of the centering of the piston pin, or you'll be doing it again very soon.
jr1983
04-14-2016 19:35:45
 Re: d-17 rebuild- Do rod bolts need to be replaced??? in reply to DrAllis, 04-13-2016 19:20:49
I'm not sure what you mean. I've done one. I'm no expert on d17 overhauls but I don't remember anything like that. My engine came out of a combine. Is it different or did I get lucky? It has enough hours on it I'm sure it's fine but I would like to know for the next one.
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: want to buy open station platform and fenders for 4430 john deere, needs to be in good condition . [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
