Company Logo Shop Now
Re: Allis WD w/no Ser. No.
please help
Brian G.
06-01-2000 06:34:08
Dennis, I suppose it is possible that there is no number on that housing if it's a replacement. There are engines without serial Nos. I have one. I would go back and do as Brian(pa) suggests: scrape the paint off real well. I've used a stiff wire brush and some lacquer thinner to help remove the paint and crud. The serial No. is located on a "horizontal" surface just below the brake spring hole and above the brake adjusting bolt/locknut. Also, as Brian(pa) suggests, look on the RH side of the left brake inspection hole, under the cover. Assuming the engine is original, I would guess your estimate of '48 or '49 is probably correct. My oldest tractor (a '50 WD) has engine serial #WD272805GA and tractor serial #WD66400.
Dennis Linton
06-01-2000 18:48:41
 Re: Re: Allis WD w/no Ser. No. - please help in reply to Brian G., 06-01-2000 06:34:08
Thanks, Brian.
I've brushed and scraped all about the top and rear of the left brake housing and cannot find any numbers. Even the machined flat surface between the brake spring and brake adjust nut does not exist.
Would you happen to know whether engines were installed sequentially according to SN. The difference between your engine SN and mine is 47,441. If I subtract that from your tractor SN I get 18959, which would make it a '49.
I think I have enough info now to order some gaskets.
Thanks again.
Best regards, Dennis
Brian G.
06-02-2000 05:12:50
 Re: Re: Re: Allis WD w/no Ser. No. - please help in reply to Dennis Linton, 06-01-2000 18:48:41
Unfortunately, there is not a direct correlation between engine & tractor serial #s. As I understand it, the stationary, combine and grader engines may all have used the same sequence of engine #s. From the few sets of #s I've been able to compare, there appears to be a difference of around 2,000 to 5,000 per year. Anyway, you're right; you certainly have it identified sufficiently to order parts for it.
Today's Featured Article - ... [Read Article]
Latest Ad: Need a grill guard for a 8n ford [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
