Company Logo Shop Now
Lumbersawyer/ AC WF Fender/ simpler plan
BobinMi.
01-28-2016 14:56:36
Lumbersawyer,
Rather than pull a wheel off in this cold of weather, I think maybe I have come up with an easier way to get the same measurements. I now have the rear measurements and the axle opening height and width. What I need is the front where it angles up.
So what if you measure from the rear lower sheet metal next to the rib, up over the top, to where it stops at the front angle iron piece. Then measure the top back to where the angle starts along the bottom, right behind where the belt pulley is, this can be done from the wheel side. Would that be easier?
Lumbersawyer
04-27-2016 08:21:07
 Re: Lumbersawyer/ AC WF Fender/ simpler plan in reply to BobinMi., 01-28-2016 14:56:36
how's it going with the fenders?
Lumbersawyer
04-20-2016 18:48:36
Let me know if you need any more measurements.
Lumbersawyer
04-15-2016 17:57:58
Figured it out, this site does not let you use photobucket. I tried to get the measurments you wanted. Any ?? cal me.
Lumbersawyer
04-15-2016 17:54:27
third party image third party image third party image
Lumbersawyer
04-15-2016 17:40:03
I don't like this forum on how it handles pictures. Please call me. or send me your email. I post pictures all the time on snowmobile chat forums using photobucket, they don't seem to work here. 2183260028-2182592901
Lumbersawyer
04-15-2016 17:34:10
http://i658.photobucket.com/albums/uu301/7doos/Misc/pic%203_zpsm2os5vud.jpg
Lumbersawyer
04-15-2016 17:30:37
Here are pictures with the dimentions written on fender. i used a carpenter's square for a straight edge. measurements are to sheet metal not braceing. the measurements of the angle front brace is where the straight edge leaves the radius of the brace. The lenght of the fender is 6' 1/4" around the top.
Lumbersawyer
04-14-2016 17:20:57
i have the measurements. I need to upload the pictures to photobucket the post them. Or I can send them directly to you.
Lumbersawyer
04-14-2016 05:48:44
I plan on getting these measurements for you by the weekend.
Lumbersawyer
02-05-2016 09:33:00
I will try to get to this. After your first post it turned very cold here. I'm into vintage snowmobiles, so I go every Sat to ride my sleds. I have no trouble with taking the wheel off to get the measurements. Weather is better, so I'll try to get this done.
f2355j
01-28-2016 16:40:44
I am assuming this is a unstyled WF? If so when I did mine I used WC fenders and cut some off the front. I also had to reuse the inner steel pannel from the old fenders.
BobinMi.
01-28-2016 15:03:08
third party image
Try this again with a photo.
Today's Featured Article - ... [Read Article]
Latest Ad: 3 JD 6600 d combines 1 w 329 1 w 404 Turbo 1w 404 non Turbo believed to be good motors also 2 JD platforms and 643 ch posting for friend call for details. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
