Re: Belly Mower for AC B
D13
05-29-2000 05:58:44
I run a Woods L306, using the belt pulley shaft, and the hydraluic lift. On/off time is 1/2 hour with a wrench and a floor jack
I agree you cannot use the tractor for the "handy" work, but if you are just going to mow with it it works fine.
Do not use biugger than 5' if you don't cut your grass every couple of days - I have burned up a couple of these tractors with 6' mowers and longer, wet grass.
You also can make a drawbar attachment to "tow" a 3-point type mower, as long as it has 4 wheels. I spent $20 in steel and welding rod, and 2 hours, and now can have my B and mow too.
