Company Logo Shop Now
I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP
mrneeky
01-08-2016 08:46:31
my i400 shift lever will not go into reverse. it stops at neutral like its hitting a wall.the manual i have does not help at all.does anyone have any suggestions on what it might be
mrneeky
01-17-2016 20:28:31
 Re: I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP in reply to mrneeky, 01-08-2016 08:46:31
no luck yet
DrAllis
01-10-2016 03:21:52
So with the spring and shaft removed, will it now shift into reverse ?????????? You have found the problem. Modifying that detent mechanism was a Band-Aid on something that is an internal problem. Yes, you have to split the tractor to work on it, and maybe even split it twice. I have never worked on one.
mrneeky
01-10-2016 10:55:43
 Re: I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP in reply to DrAllis, 01-10-2016 03:21:52
actually, no it did not go into reverse when i removed the spring and shaft . is there a manual to help you split a tractor?
DrAllis
01-09-2016 20:30:30
I'd be removing that silver thing underneath your shifter lever that sticks out about 4 inches. Someone has clearly messed with it by the welding done to it. It should not stick out there that far. It is the detent spring and ball on the inside for the shifter. Don't know what you're going to find when you remove it.
mrneeky
01-17-2016 20:29:38
 Re: I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP in reply to DrAllis, 01-09-2016 20:30:30
no luck yet
mrneeky
01-10-2016 00:27:07
i talked to the previous owner and he said he made it stick out like that because he put in a longer, stronger spring due to the older shorter one allowed the tractor to pop out of reverse. so he modified it.It was working fine, but im guessing if there is supposed to be a ball at the end of the spring and shaft, it fell out, or someone else suggested the turnkey fell out. Does the tractor have to be split to fix either of these problems? and if so, where does someone get a manual on splitting a tractor?
mrneeky
01-10-2016 00:30:23
 Re: I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP in reply to mrneeky, 01-10-2016 00:27:07
i mean key woodruff
mrneeky
01-10-2016 00:00:55
i removed it and could see a spring and shaft, no ball.
mrneeky
01-09-2016 23:57:52
took it out, could see a spring and shaft , no ball.
Nordic
01-09-2016 15:05:37
Is it your forward reverse lever that won't go into reverse? Or is it the main transmission shifter you are referring to? If it's the latter Dr. Allis has the answer above. How long have you owned and operated this machine?
mrneeky
01-09-2016 16:51:39
 Re: I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP in reply to Nordic, 01-09-2016 15:05:37
it is the forward-reverse lever. i have only had it a month and it was woring and the leve just refused to move to reverse one day
mrneeky
01-09-2016 16:55:50
 Re: I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP in reply to mrneeky, 01-09-2016 16:51:39
third party image
pic of lever
mrneeky
01-09-2016 17:04:20
 Re: I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP in reply to mrneeky, 01-09-2016 16:55:50
third party image
third party image
lever
DrAllis
01-08-2016 09:21:25
If it has a "shuttle" shift lever (F-N-R) there is no reverse in the transmission, it's blocked.
mrneeky
01-08-2016 23:11:37
 Re: I400 FRONT LOADER TRACTOR Alli's chalmers-NEED HELP in reply to DrAllis, 01-08-2016 09:21:25
do you have any ideas what its hitting
mrneeky
01-08-2016 09:29:08
i cant find a manual that will help me find the problem and fix it.do you know wht i should do?
Latest Ad: Looking for a gearbox casing that mounts to a Clinton Machine Company motor Model B764COC Serial# 2070576 part# 3801-C. It powered a Bolen 2 wheel walk behind tractor late 1940s model. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
