G tractor plow gauge wheel
Superpickle
New User
Hello, I have been looking for a gauge wheel for a bottom plow on an Allis Chalmers G tractor with no results. Does anyone have the specs on the gauge wheel so I could have one fabricated or have any other suggestions? Thank you
For front mount modlboard plow, parts book indicated the wheel was 13" diameter prior to June '49. After that the wheel was of different design - no diameter given. Sorry, no other dimension shown on either.
I'm assuming this is the correct wheel for the 1 bottom plow.It is 13" diameter, 6 - 3/8" dia. spokes, 3" width. The mounting bracket is 1/2" X 1 3/4" flat stock.
Let me know if you have more questions.
That sure looks like the sketch of the early one shown in the parts book. The later one is sketched as having 4 wide flat "spokes" bolted to the hub and welded to what is a more flat rim.
